For those who like to use their local NAPA, the CFB5000 xref's to a WIX number.
Part Number: 24019
UPC Number: 765809240193
Principal Application: Conversion Base For Cooling System Filters - 11/16-16" Threaded Base Stud - Inlet + Outlet has 3/8" NPT
All Applications
Style: Filter Mounting Base
Service: Base
Type: By-Pass
Note: Spin-On Conversion Kit
Principal Application Universal Mounting Base For Cooling Filters
Here's the B5134
Part Number: 24070
UPC Number: 765809240704
Principal Application: Cooling System Filter with No Chemicals
All Applications
Style: Coolant Spin-On Filter
Service: Coolant
Height: 5.214
Outer Diameter Top: 3.694
Outer Diameter Bottom: Closed
Thread Size: 11/16-16
Burst Pressure-PSI: 200
Nominal Micro Rating: 27
Note: Service: SSI
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.834 2.462 0.200
and the B5088
Part Number: 24083
UPC Number: 765809240834
Principal Application: Extended Drain Coolant (Non Chemical Filter)
All Applications
Service: Coolant
Height: 4.173
Outer Diameter Top: 3.690
Note: Cooling System Filter with No Chemicals
Prinicipal Application-Cat, Cummins, Detroit, Other
Service-ESI
Gasket Diameters
Attached 2.850 2.470 0.230
Note the different services. One is SSI
and one is ESI
Standard Service Interval
Extended Service Interval
(which appears what others have asserted)
