Coolant filter
Don't know about the insides yet but this is a Baldwin B5089 coolant filter. It has a very small opening and the threads are 11/16-16. Some have chemical disc in the too.
That's a restrictor orifice, designed to limit flow through the filter (so that if you install it between the 2 heater hoses, you'll still have heat). The coolant filters I've cut open appear exactly the same as a cellulose oil filter (except for the orifice).
I have mine plumbed in on a small 3/8" radiator bypass hose that goes from the upper radiator hose to the water pump. T-stat is on the lower hose at the water pump.
