Another Transporter related question.
I noticed some debris in the bottom of the expansion tank. Nothing major, small black flakes. Possibly from previous work done or deterioration of hoses and seals over 18 years and 215,000miles.
I've already drained the coolant and will be cleaning out the expansion tank before I fill back up.
I'm wondering if there's any benefit to running a coolant filter? If it makes any difference, I'll be using a Glystantin G40 coolant which meets the requirements of G12++ that the van left the factory with.
There is a small hose (approx. 10mm in diameter) that goes from the heater matrix manifold in the engine bay back to the expansion tank. There is a constant flow of coolant through this for what I assume is bleeding purposes. Could I throw a little inline fuel filter in there? Would a fuel filter cope with the 100°c coolant temps?
