While reading of Rad Flushes I notice the rad is flushed several times to clean it out. What does one do with all the coolant and water then removed ? Is it all collected in containers to be recycled ? A lot of it would be very weak solutions ( mostly water. )Does one just let it run away ?
Why use distilled water for flushing ? Isn't tap water good enough ? I can understand using Distilled water for the final filling.
Thanks for all the good information posted on cooling systems.
