- Joined
- Dec 7, 2012
- Messages
- 3,562
I'm really splitting hairs here... reading different opinions on coolant and not sure which way I want to go.
Swapping a 2007 LQ4 6.0 into my 2005 Tahoe. Tahoe had Dex-Cool, but has been drained and filled with Prestone All Vehicles (yellow jug/lime green-yellow color) a couple of times -- reserviour looks mostly yellow-ish. The LQ4 had Dex-Cool and there's probably still some in the block.
I am confused as I am reading that the Prestone is essentially a Dex-Clone, or something about 2EHA... I'm just a little lost. I do have a couple of new Jugs of Peak 10x coolant sealed.
My options are:
1. Blow out heater core, rear heat lines + rear heater core and radiator (best I can) of the current coolant and re-fill with Dex-Cool.
2. Re-fill with Prestone All Vehicles (what was last used)
3. Re-fill with Peak 10x
What one would you use? I used to think the Peak 10x was the same as the Prestone All Vehicles.
Maybe I'm overthinking this?
My options are:
