Originally Posted By: Boss302fan
Originally Posted By: MADMIKE
Why do most new vehicles come with a long life coolant that can go 90,000 miles+ but then have to be changed much more frequently after the initial fill? My 2007 Nissan specifies 90,000 on the first run and after that every 30,000 miles, doesn’t make sense to me.
First of all, I would not wmait 90K miles... I would do a radiator drain and fill every 30K or 2 years.
I don't have any data to back this up, but my opinion is that the long-life coolants are good for their prescribed interval.
It is also my opinion that the shorter subsequent intervals are based on a radiator drain-and-refill, which replenishes only 1/3 of the additives.
I also believe that being dirty is not one of the reasons. In a well-maintained system (ie, not touched for the duration of the first interval,) an oxide layer should have formed and the coolant additives slowly depletes over time, which is the only reason the coolant needs to be replaced over time, in most circumstances. Without a head gasket issue, the only ingress of "dirt" would be from addition of distilled water or mixed coolant into the coolant reservoir (minimal.)
So, it is my opinion that the system should be touched for the full interval unless a known problem exists.
