Is this a straight forward drain/fill? I bought 2 gallons of Peak Global Lifetime 50/50 (9.99each at 7-11) to go in... There is a little bit of buildup inside the coolant tank, so I plan on removing that and attempting to clean it.
I assume most of the sediment, if any would come out through the lower radiator hose if I removed it? If there is, It would probably behoove me to do a flush..
