conventional Valvoline or PYB for 5000 OCI?
I personally believe Pennzoil has the better base stock and additive package. Unless something has changed, Pennzoil conventional uses a Group II+ base stock with an Infineum - Afton additive package. Valvoline (WB) uses a Group II base stock with the standard Lubrizoil additive package.
The Pennzoil uses Shell-vis VI Improvers which are some of the best out there.
Valvoline is a good oil, but I would not use it because I do not like the company.
Or the bottles. ^^
The white bottle add pack looks kinda weak. Having said that, it does return good UOA results, whatever that means. Again, I think Pennzoil Conventional is the better oil, but the white bottle will do fine for you as well.
I think they are both good oils but Pennzoil Conventional 5 qt. jug is cheaper at Wal-Mart
