UG.
Thanks for the quick reply.
Now I look, I wasn't clear enough with my question. I'm looking for the manufacturer's specs for charging the battery, which generally list the voltage and current to be maintained at different stages of the charge. _And_ the full charge resting voltage after surface charge has dissipated, and the self discharge rate. I would hope to find very exact specs for these value.
I have a Pro-Logix PL2140 maintainer with what looks like (from their literature) a 4 or 5 stage charging profile. They describe:
- "fast charge"; which I measure at various voltages, peaking at 14.6v - presumably, current would be 4amps
- "absorbtion"; " at 14.3(?)v, current reducing to below 2amps
- "completion" " at 12.6(?)v, current dropping more and approaching 0amps
- "resting" " at 12.4(?)v when the charger drops into maintenance and essentially shuts off until it tests at some later time and tops off. I am unsure of the exact voltages because I have not tried to test rigorously every 10 minutes or whatever over the 3 or 4 hours the charger will take to cycle after I discharge the battery below 12.2 volts recharging from 12.2 takes more like 8 hours with this maintainer - s/b "after battery volts drop below 12.6". I have only checked on it as I get a chance while doing other stuff.
I'm going to get on Pro-Logix about _their_ voltages, which seem low to me (except the initial 14.6v a few minutes after connecting for any charging).
However, before talking with Pro-Logix, I would much like to find Interstate's official specs on how they want their battery charged, various voltages and switching points; and, particularly, what the battery's fully charged resting volts s/b after surface charge has gone. To the 1/100 volt if at all possible.
Unfortunately, I have a bit of attitude about the responsibility and expected integrity of companies producing a technical product for which good care and handling requires specific information be readily available. At the very least. Honest detailed specific instructions on the importance and consequences of said information and care would be a big plus over and above the data itself. Unfortunately, this information has begun to look like it may not even exist in the case of Interstate batteries.
This lack looks to mean the next time I need a battery I have to see if a product has data available before I consider it further. I had just assumed... When I get more time I'm going to do a search for the battery specs of different makes/models and if I can't find any info, put that battery on a black-list.
But I'm still trying to think Interstate is just a bit backwards about publishing and has not simply stopped providing any customer access to detailed (and important) product data. Maybe because "if we don't provide any info, nobody can call us on it..."? I certainly hope not. It's hard to believe that fleet managers and large OEM's would go along with that crap.
Regards,
Rufus
