I've been trying to establish a few points regarding your Northstar batteries.
1: The smart charger deciding to never read above 75%, might mean absolutely nothing.
If it stalls at 75%, what is the amperage it is accepting at the voltage the charger is holding the battery at? This is highly revealing data, far more than a 75 number which never changes and likely has no basis in reality. I have seen voltage displays on chargers being as much as 0.4v off. The charger is reading voltage at the DC output at the circuit board of the charger, not at the battery terminals. The voltage at the battery terminals will be lower, and it will be lower the more amperage the battery is accepting from the charger, and will be lower the longer and thinner the wiring is, due to voltage drop on the DC output wiring.
Generally at high states of charge the battery is only accepting 1 amp or less, and the less amperage that is flowing through wires the less voltage drop on the wiring from source to load. A 25 amp charger should be using 10 AWG wiring. It likely uses 14 as 14awg is rated to carry 30 amps, but 14 awg will drop several tenths of a volt at 25 amps. The battery would accept slightly more amperage for longer and recharge slightly, but measurably faster if the cable from charger to alligator clamp at battery were 10awg instead of 14, or worse, 16 awg. My 25 amp schumacher used the worst quality 14 awg I've ever seen. I could not believe how hot it would get passing 25 amps. When i replaced it with 10AWG it worked better, and its max outptu was closer to 28 amps.
Some chargers get the voltage at circuit board to say 14.6v, then instantly drop to 14.2, though this tends to happen on the flooded/wet settings rather than AGM. With undersized wiring, the voltage at dc output at circuit board will read 14.6, but the voltage at battery terminals will be upto a few tenths of a volt lower. This in effect, potentially never gets the battery to absorption voltage at all, and this is a Big No No in deep cycle duty, especially AGMS, especially TPPL Agms like Northstar/Odyssey. My dekas once I get them to 14.4v, I can lower voltaqge to 14.1 and amps only go down by 0.5 or 0.9, but my Northstar if I get voltage to 14.7v then lower voltage to 14.4v, amps drop by no less than 5. This is just one example of the weird personalities that batteries will exhibit when one looks closely with the right tools to do so. The Northstars I bring to 14,7v and hold them there, the Dekas there is little benefit from holding them at their 14.4 spec once they have reached it, so I lower it to 14.1 or so, sometimes even 13.9v and wait for amps to taper to 0.3 before turning voltage down to 13.4, or just turning off the power supply entirely.
2.
The repair mode might to its magic crystal resonating pulse thing, or it might simply bring the battery to a high absorption voltage and hold it there for a few hours. Im not going to research to see what either noco or optimate says it does.
I've stated my opinion on the magic resonating sulfate crystal thing, but an additional 4 hours held at 14.8v stands a very good chance of charging a sulfated battery to a slightly less sulfated state.
3. A battery at 85% charged or higher, cannot accept high amperage. If it pumps out 25 amps continuous, it would quickly push the voltage well over 15, which is to be avoided, especially with AGMS. The charger is going to limit voltage to 14.8 or so, and will only produce enough amperage to maintain 14.8v. This amperage will taper farther and farther towards zero the more full the battery gets.
4. the high amp recharge from a well depleted state is the best way to potentially dissolve hardened sulfation and restore lost capacity and cranking amps.
HIgh amps recharging........ applied to battery.............. when it is well discharged. 80% charged is not well discharged.
You cant push high amps into a battery unless it is well depleted, no matter how high you set the pressure/voltage.
Even if the charger says 25 amps, and you set it to 25 amps, on an 85% charged group 34, it will accept 25 amps for less than a second, taper to about 15 amps in 5 to 10 seconds, and taper to about 10 amps in 30 seconds and then over the next 3+ hours taper towards zero amps, IF the charger even holds absorption voltage for that long, which is unlikely.
This is too little amperage, and too little time to heat the hardened sulfate and potentially dissolve it back into solution, opening up the clogged plate pores, restoring capacity and CCA.
To get high amperage into a battery it must be well depleted. The more depleted it is, the longer it can accept high amps, the more it can heat the hardened sulfate, and the better the chance it then redissolves into solution and restores capacity and CCA.
You can drive 6 hours, then put the charger on restore mode 10 times in a row and have it do nothing other than add to your electric bill.
you can drive 6 hours then turn engine off and leave headlights on until voltage falls to 11.2, then turn off headlights, plug in the charger set at 25 amps, and that WILL do something, or at least it stands the best chance of doing something. When it shuts down put on the charger which says it takes 4 hours to restore/recondition as this is likely just an extended absorption voltage stage cycle, but check to insure voltage does not exceed 15!
5, without knowing the voltage your vehicle holds as you drive, you have no idea of the state of charge of the battery, and it is unwise in the extreme to assume that it must be fully charged because you drove 6 hours. It could be doing the MPG thing where the voltage regulator sends no field current to the rotor and the alternator places no additional load on the engine when it is most advantageous to add 0.06mpg.
You could fully charge your battery on your charger, leave home at 99% charged, drive 6 hours to your cabin, and arrive with an 80% charged battery and perhaps burned a few less thimbles of fuel than if it had held 14.4v for 10 minutes then 13.8v for the final 5 hours and 50 minutes.
6.
Sticking a charger on a battery, and the charger declaring a % of charge, and believing what the charger says, is unwise in the extreme.
Voltage is ONLY indicative of state of charge on a well rested battery. well rested meansing a battery which has not seen either discharging loads, or charging sources applied for several hours. If you place a charger on a battery that has just been on another charging source, the voltage will likely be artificially high, as it has not had time to bleed off.
This surface charge voltage can and will stick around on a healthy AGM for DAYS when there is no loads applied to the battery. Place a smart charger on a battery that reads 13.4v surface voltage from another recent charging source, and it thinks it is already fully charged and will go right to float mode. This 13.4v artificially high surface charge does not indicate the battery is full, nor does it mean it is healthy. It could still be only 84% charged and 80% state of health, and need 3 hours or more being brought to and held at 14.7v before its anywhere near 99% charged.
But the smart charger saw 13.4 volts and assumed it was already full and went right to float voltage, so instead of 3 hours till full charge, it takes 4 days at 13.4v, or whatever the float voltage set point of the charger is. The old sulfated battery stands little chance of ever reaching full charge at float voltage. One could leave ithe old abused sulfated battery plugged in for weeks at float voltage, and never get it above 90%. Its like a balloon with a bunch of tiny pinholes letting the pressure escape.
So back to the first thing I typed in this thread. trying to determine state of charge, or state of health of a battery, by what some smart charger displays, or does not display is a frustrating, confusing lesson in futility and means nothing.
Perhaps just slightly more than nothing, when one generates enough experience with that charger and many other tools which actually can reveal data which corresponds to reality and has the gumption and aptitude to play battery detective/ battery whisperer.
So the suspected weak northstar, drain it to a low voltage, then high amp recharge it with no less than teh 25 amp charger, then press the 4 hour magic restore button and hope it holds absorption voltage for an additional 4 hours. There is no point in pressing the magic restore/recondition button over and over without first draining the battery to a low voltage/ low state of charge then immediately providing it with as much amperage as you can muster.
It is possible to put two chargers in parallel and combine their amperage, but one needs the battery to be well depleted and start both chargers quickly, so that one charger does not bring the battery above ~12.7v before the other charger gets started.
Also, whencombining charging sources in parallel, once they together gets the battery to around 75 to 85% charged, or the maximum voltage of one charger or the other, then that lower voltage charger will just stop, and can be removed. Their combined amperage is not needed at that point anyway.
A guy on an RV forum used to combine 4 older VEctor/ black and decker 35 and 40 amp chargers on 6 golf cart batteries, in order to reduce the time it took to get from 50%to 80% while running his noisy gas guzzling generator during limited genertor run hours.
He later just got a100 amp and a 55 amp adjustable voltage power supply put them in parallel, so he did not have to stuff/stack 4 sets of 14 awg weak alligator clamps on a battery bank.
I used to combine my 2/12/25 amp schumacher charger with my 40 amp meanwell power supply for 65 amps of charge current, before I got my 100 amp adjustable voltage power supply. One time pre 100 amp power supply, I also added a transformer based old school 2 and 10 amp transformer based charger to the smart charger and the power supply, but later determined the 10 amp setting this POS manual charger only makes 4.2 amps max on the 10 amp setting, and its not worth the effort to get 69.2 amps rather than 65.
If I can source two different 15 amp household circuits, I can, and have combined the output of the 40 and 100 amp power supplies, and managed 138 amps into my group 31 Northstar which was depleted 67 of its 103 amp hour rating. I can get 122 amps from one of my alternators and 116 from the other, though I've not tried to combine them both, yet.
While I cant say for sure, 65 amps seems to be the most rewarding amount of amperage to feed my G31 northstar when it gets lazy from too much floating, or when I have done a bunch of cycles either not getting to 100% charged, or a bunch of lower slower recharges to full at no more than 12 amps/~ 200 watts of solar panel.
The 100 amp adjustable voltage power supply, I set its voltage to 0.1v above battery voltage, then hook it to well depleted NS battery, then twist the voltage dial upwards until it delivers the amperage I desire, upto its 100 amp limit. I have not noticed 100 amps being more advantageous than 65 to smack the lazy northstar back to expected performance, so unless time is of the essence, I control amp flow with the voltage dial in order to not exceed 65 amps.
My adjustabe voltage power supply's voltage dial is kind of similar to a throttle pedal. The higher I turn it the more amperage is generated, at least on a well depleted battery that has not yet risen to absorption voltage. It's very enlightening.
