Mine is going into the dealership on Monday for an oil change, also to check the injector programming, software/firmware and EGR system. My wife's 2020 CRV has only 4200 miles and has had 2 oil changes as she uses it as a grocery getter. A used oil analysis is in the works for hers, I'm surmising that hers may have some dilution, however I am also suspicious that mine may have something wrong that's causing the problem as my previous Civics had essentially the same engine and were driven in a similar manner had no dilution issues. Mine has 20k miles and is still under warranty as well as Hondacare.
Right! I think that your CR-V may have something slightly amiss.
You're doing the right thing by taking the CR-V into the dealer and at least getting some documentation of the issue.
Your Civic and CR-V have the same 1.5T engine with different programming & horsepower/torque ratings. The software in your CR-V is closer to the Accord's 1.5T. However, the CR-V seems to be(statistically) showing more fuel dilution issues than the Civic or Accord (if any).
And your wife's CR-V may [MAY] show different results, we don't know yet, even though they're the same vehicle/year/drivetrain.
Probably they were built on different days using some different vendors for certain parts? Car companies(all companies) use different vendors for same parts all the time, just in case one vendor has in house problems, the car company can fall back to the other.
OR, the parts coming from the same vendor may have been slightly out of spec?
No car company makes ever single part themselves, they use specialty companies for parts that they/themselves don't produce. Like steering wheels, headlight housings etc. The car company designs them, other companies produce them under their(Honda) specification.
Quick story:
In 1988, my buddy and I both bought '88 Honda Accord LX sedans auto transmission w/carburetors(not EFI). We bought from different local dealers at different times(literally a few days apart).
*My car was built in Ontario, Canada and his was built in Ohio, USA
*His ignition system was a Hitachi and mine was a TEC
*His car came with Bridgestone tires and mine came with Michelin
*My car had a terrible in gear at idle vibration(that was actually prevalent in many) that the dealer could never rectify even after motor mount change and his ran smooth as silk
*I had issues filling my gas tank with the gas handle squeezed all the way(clicked off all the time) and my buddy had no problem.
*His car always seemed to ride a bit better than mine(we both agreed)
**Both of our wives hated the car!
EDIT: Here's a video talking about the fuel dilution on CR-Vs. It starts around 7:40-7:50 in the videol
