I am considering a Infiniti 2017 QX50, AWD. Does anyone have any experience with these or the 2016 year model of same?
Im kindof gravitating away from DI and Turbo engines. Yes the performance is there, but I'm a bit leery of them, as a whole, past 200k miles. Or even past 150k, when my warranty in the cx5 runs out.No go on the GV70?
Yeah, id forgotten that bushing. Seems as i recall you domt have to fix it immediately, so while annoying and expensive, it wont deadline the car, no.Other than the liquid-filled differential bushing being a guaranteed failure item, they are very reliable. The 17 already has the updated oil gallery gaskets.
Radiators are a semi-pain to do.
Just a very dated, reliable and space-inefficient vehicle.
Its port injection, I believe.The VQ engines are some of the best around. However, that 2017 has the 3.7L variant, which is in fact, direct injection.
Engine Specifications | |
Engine code | VQ37VHR |
Layout | Four stroke, V6 |
Fuel type | Gasoline (petrol) |
Production | 2007-present |
Displacement | 3.7 L, 3,696 cc (225.53 cu in) |
Fuel system | Direct Injection |
Weird. Most of the car mags seem to think it does not have direct injection.From https://www.engine-specs.net/nissan/vq37vhr.html
Engine Specifications Engine code VQ37VHR Layout Four stroke, V6 Fuel type Gasoline (petrol) Production 2007-present Displacement 3.7 L, 3,696 cc (225.53 cu in) Fuel system Direct Injection
2016 Infiniti QX50 Driven: The 80-Percent Solution
Stretching the point is the point.www.caranddriver.com
Im unaware of any. I think its just bunk websites. They are all rated at 325(suv) to 350bhp(370z nismo, due to nismo exhaust). DI would have increased it.There is a ton of conflicting information all over the interwebs. Some versions of the VQ seem to be direct injected, others are not.
I don't know, I've seen it in multiple places that it has direct injection, as least in later years. I could be wrong.Weird. Most of the car mags seem to think it does not have direct injection.
My 300ZX has liquid filled tension rod bushings. They started to ever so slightly weep eventually but gave me no probs. But I replaced them one weekend.Yeah, id forgotten that bushing. Seems as i recall you domt have to fix it immediately, so while annoying and expensive, it wont deadline the car, no.
One quick look under the hood and you'll have the answer. The HP fuel pump is on the cam / valve cover of the front bank of cylinders, has a black foam cover to attenuate some of the noise it makes.I don't know, I've seen it in multiple places that it has direct injection, as least in later years. I could be wrong.
