...in a diesel engine which usually calls for an 15w40? I have seen used oil analysis on here by "patman" and "arkapig" using HDEO 10w30's in their duramax engines with quite stellar results. This throws my logic about oils right out the window, as in my mind at least with a diesel engine you have severe loads placed on journal bearings due to the diesel engines torque, and I thought in a situation like this you would need the protection of a 40 weight oil to prevent metal to metal contact? What am I missing here? Is it the additive package which takes effect when/if you do get metal to metal contact? I do know that you have better resistance against shearing with a 10w30 vs a 15w40, but am still confused. I have even heard of some duramax owners in the brutal heat of texas using rotella T5 10w30 year round AND towing! That would make me a bit skeerd.
