yup.. that's awesome.. That reminds me.. I have the Apple //e with the (12" or 13"green text) Monitor /// (was for the apple ///) in storage! forgot all about that.Don’t have one, but was teaching when Radio Shack TRS-80’s with audio cassette players for drives were introduced to the classrooms. When we got Apple II’s with 5 1/4” floppies we thought we were in tech heaven.
When the cassette tape drives wouldn’t load, you’d have to fiddle with the volume control to get it to load. Spent a few planning periods trying to get Oregon Trail to load.yup.. that's awesome.. That reminds me.. I have the Apple //e with the (12" or 13"green text) Monitor /// (was for the apple ///) in storage! forgot all about that.
Ah the joys of the 24 bit address, yeah very rare a 16bit system could handle larger than 4mb simmsI tried upgrading the RAM in the CompuAdd system from 4MB to 16, but I couldn't get it to rcognize more than 4, either the BIOS is limited, or they shaved off BOM cost by leaving a few address lines disconnected with was apparently a common thing on 386SX systems as they were sort of the "Celeron" of their time frame.
RAM holes were still a big problem up until the second iteration of Core2 chipsets, my T60 I pictured further up has 4GB installed, the 945 chipset has exactly 32bits of address space and but due to the way the memory mapped I/O is configured on the BIOS, only 3GB is accessible even in a 64-bit OS, I only have 4GB installed because DDR2 is worthless now and that puts all the RAM in dual channel, but back when the RAM still costed a decent amount it was typical that people would only install a 2GB module and 1GB module and run it in mixed dual channel mode where the first 2GB was accessed in dual channel but the last gigabyte had to be accessed in single channel.Ah the joys of the 24 bit address, yeah very rare a 16bit system could handle larger than 4mb simms
Unlike most computers later IBM 286 systems would “see” more than the 16mb limit but anything beyond 16mb was only available as expanded memory and depending on your expansion cards a good chunk 1.375mb of that 16mb extended ram was masked for video cards. (Unusable)
My experience is that most 286/386sx systems could not be expanded to the full 16mb generally 12mb was the real limit because of the dos memory hole.
A few machines could go to 14mb (on paper) if you turned off ram relocation but good luck finding a combination of ram that actually added up to that strange amount
What system were you working with that had that much RAM?I remember having to tell the Linux kernel when more than 16GB of RAM was installed with a kernel boot parameter, because it couldn't auto-detect memory above 16GB. That was in 1998-99 or so.
Working with Linux systems > 16GB RAM in 1998 meant you were a very cool cat!I remember having to tell the Linux kernel when more than 16GB of RAM was installed with a kernel boot parameter, because it couldn't auto-detect memory above 16GB. That was in 1998-99 or so.
Are you sure it wasn't a little later than 1998-1999, the quad processor P3 Xeon servers I know of usually maxed at 16GB back then and I'm not even sure the RAM modules necessary to max them were even available at the time or if they were the prospect of buying 16 of them would have been astronomically expensive.Many systems, I worked for a company that offered "dedicated servers" in their own datacenter space.
Could have been HP Convex SPP2000's.What system were you working with that had that much RAM?
16GB sounds more like late 01 to sometime in 03. in the 98-99 time frame, any person would have been very lucky to have seen a single system with 16GB RAM, even each node in HPC clusters probably didn't generally run anywhere near that.It probably was later than that, now that I think about it. I left that job in 2003 so it couldn't have been later than that.
There were a few companies like Compaq, HP, Tandem, and a few others that made large scale x86 servers during the 1990s based on the Pentium Pro. I don't remember the max RAM, but it was a LOT for back then, maybe 64GB.What system were you working with that had that much RAM?
From what I can dig up, 2.0.x kernels apparently had a lot of problems detecting RAM above 64MB and you had to manually specify the size and aparently had another limit around 1GB through the 2.2.x kernels, the 2.4 kernel added support for PAE and raised the limit to 64GB, although that was the point it was committed to mainline RedHat may have made their own patching beforehand, and I'm not sure about non x86 ports.After thinking about it some more it was almost definitely linux kernel 2.0.x and it was definitely the mem= parameter I used to tell it how much memory the machine had. However, a Google search turned up nothing about this, not surprising since it's been at least 20 years since it was a problem. Maybe I should create a VM with an old Redhat version that uses kernel 2.0 and see how much memory it detects...
