Originally Posted By: daves66nova
I have an old Pavilion a1630N that i want to put in my son's room for a game he likes to play. whenever I d/l any program,it'll download but not open whenever I double click on it. I just reformatted this comp yesterday. It does have XP on it. I am using the latest version of Mozilla and it does work great with it ,it just does not open programs. I know that I can get a newer comp, but this is just for his room and for a game. What can i try?
This feature is also used by newer versions of Windows as well. Personally, I have encountered this in Vista, 7, and have read that users experience this in 8 and 10 as well. Please click the links below for explanation. They will explain the various reasons/applications/parts of windows that cause this to happen with some downloaded (or even all downloaded) files. Also, there is an app out there and other how-to's that explain how to permanently disable this from happening. (just be aware it will reduce security to some extent depending on what you are downloading)
This is driven by the alternate data streams. Windows flags files as potentially untrusted if they have been downloaded (for example) from the internet zone and will disable execution.
As a side note, Sysinternals provide a free tool called 'streams' (via Microsoft) which allows you to remove (including recursively) all alternate streams from a file / directory.
As a second side-note, the reason Windows does this is because it's a fairly simple way to construct a trojan or virus. As discussion on this briefly here.
In 2009, the alternate data stream was used by a click fraud Trojan named FFSearcher. It used the stream name “Zone.Identifier” which is a stream name that Microsoft uses to mark executable files downloaded by Internet Explorer. Instead of a simple zone identifier however, the Trojan implanted a DLL file that contained the Trojan’s code.
How to permanently unblock files that ca...ked Files in IE
Simple Explanation & How To Unblock
Best Explanation & Solution
Hope this helps.
