I grabbed the service manual for my Geo Prizm about this. "Normal [spark plug] service is assumed to be a mixture of idling, slow-speed and high-speed driving. Occasional or intermittent highway driving is needed for good spark plug performance. The higher combustion temperatures generated during highway driving burn away carbon and oxide deposits that have built up from frequent idling or continuous stop-and-go driving."
"A spark plug one step higher/hotter in heat range might deliver longer service life than the spark plug recommended for almost exclusive city driving. Conversely, a spark plug one step colder than recommended will perform better for continuous high speed driving."
So basically it's said right there that colder plug means it runs a colder combustion chamber.
"There are three rules to follow when selecting spark plugs for an engine in good condition:
1. Select a spark plug with the specified heat range.
2. Should the spark plug overheating occur, choose a spark plug that is one heat range lower than the specified heat range.
3. If fouling is a problem, select a spark plug that is one heat range higher than the specified heat range."
I hope this helps. It makes me want to try a step colder plugs in my own car as I've noticed some pinging that I hear when things are hot driving in the city after coming off the highway and I rarely idle or have trips that don't involve a stretch of highway. Could a slightly cooler combustion chamber make a slight change in oil consumption perhaps?
If you want to try it, I would recommend pulling them and checking for carbon deposits after driving with them after a few hundred miles to see how they are doing. I'd verify that it is only one heat range in difference though as more than one could cause issues.
