Actually, I didn’t mention viscosity in my initial post, and was attempting to get beyond the endless “my favorite multi-grade vs. yours” debate.
My intention was to discuss the issue of cold start-up wear and if it can be eliminated thru the choice of lubricant in the crankcase.
Here’s a statement from the
Castrol GTX Start-Up Product Data Sheet :
Castrol GTX Start Up is a motor oil that is specially formulated to provide superior start up protection. The rate of engine wear is higher during the first 10 minutes of each trip. Superior protection during these critical minutes after start up helps prevent engine wear, and potentially provides longer engine life.
Note the use of the phrases “helps prevent engine wear” and “potentially provides longer engine life”. Castrol is not claiming to eliminate start-up wear, only a reduction in the amount.
Now, here’s another statement from an
Engine Oil Additive firm (Not a BITOG sponsor):
"When you start your engine in the morning, it runs for up to 60 seconds on the oil film left from the night before. Scientific studies in operating engines have shown that the wear rates are close to 50 times greater during starting than during running."
In addition, this engine oil additive firm claims the product “Eliminates harmful cold starts”.
Does anyone share the viewpoint that it is possible to eliminate all cold start wear?
