Car has been a stone axe for the last 282,000 miles. Thanks to Terry Dyson, found a coolant leak, guessed it was the intake manifold. My father is a mechanic of 40+ years, so he did the work. Car always ran a little warm. Now, it runs cold. Barely breaks 160. I put a new thermostat in (a Stant SuperStat, 192-195 OEM everything). Temp comes up slowly, just barely above 160 (indicated, and guage has always been accurate), and the (like the superstats are supposed to) hovers around that temp. Ambient temps are in the 20's (F), and I don't get doodly for heat out of the heater until it's good and warmed up.
RPM helps -- since he Buick is geared /really/ tall (1400 RPM at 70). So if I'm cruising about at 1200 RPM, I don't much heat. If I put it in drive (instead of OD), I get plenty of heat, although the guage doesn't move. When we did the t-stat, and were burping the system, we both noticed that flow from the heater core back into the radiator is not very good.
It's not consuming any AF that I can tell, and the oil looks /perfect/ (it's had Mobil 1 it's entire life).
A few days ago, with about 100 miles on the new t-stat (t-stat replacement was about 150-200 miles ago), temp came up to 250-260 indicated for, oh, 10 seconds then /rapidly/ came down -- we both think it was a stuck air bubble. Since then, it's been just fine, but low temp. Pre-repair, temps would hover in the 195 range pretty easily, but she'd ping like there was no tomorrow, even with 93+ octane. Post-repair, no ping (except perhaps a very slight ping for a split second from the cruising to acceleration transition). Lastly, the EGR hoses were clogged completely, although the EGR valve looked just fine when cleaned.
I have plans on hooking up an "OTC 2000" to it, when I get a chance, but it might be some time. The onboard computer should have compensated by now.
So. That's alot of information, hopefully everything ya'll need to help me out. Does anybody have any ideas?
