JHZR2
Staff member
Hi,
My 1930's house is a regular foursquare, but the kitchen is somewhat of an "extension" off the restof the house. About half of the kitchen volume falls within the "square" of the house structure, the other half is a single-story structure that goes off the house. its all original, there is basement below and it is all the same cellar walls, etc.
But the roof above just makes an open triangle which is not insulated as far as I know. The walls do have some old, white fluff blown-in insulation, but the walls are still cold.
The rest of the house holds heat well enough, it is not drafty, is pretty consistent, etc. The half of the kitchen that has the roof right overtop is cold, floor to ceiling.
My house only has one zone, but it stays comfortable consistently. The rest of the house will be at 63F like we maintain it, and the kitchen is 54F.
The kitchen does have a radiator like the rest of the rooms, and it puts out good heat.
So what can I do to warm this? Would putting insulation under the floor (like between the joists in the basement) help? Im going to close up the stud pockets from down in the basement (I cant access above), would that help much?
Ultimately I will add insulation up above, when I pull down the ceiling (the old plaster has a couple cracks, so might as well pull it before sheetrocking). But until then, I want to make it better.
The raditor is possibly a bit undersized for the collective kitchen and butler's pantry which is attached and not heated. Any recommendations for a small, tasteful space heater (the house has classic cast iron radiators, so modern baseboard heat would look funny).
Thanks!
Thanks!
