cold flow
SD
Does anyone know which conventional oil has the best cold flow characteristics? I will soon begin an ARX treatment in a '96 Intrepid 3.5, so I will need a conventional oil. SD winters can get cold, so I want the oil that will provide the best protection in a cold start situation. Thanks in advance.
Jeff
Yes...that would be a 5W as 0W's only come in synthetic/synthetic blends. That said, a 5w-20 will be somewhat better than a 5w30 or 5w-40(also synthetic. only).
Notice in this case (GTX) the 5-30 pumping viscosity at -35 is actually better than the 5-20 and at the same CCv at -30. This also bears out what I felt about Castrol oils in general, across the board they seem thicker at cold temps /until reaching operating temp than most other brands.
could the 5-30 in this case be using a higher percentage of higher group basestock than 5-20?
Unfortunately, Castrol lists this cold temp data as the maximum requirement for the grade and it is not the actual test results.
In other words, "Yawn, yeah it meets da spec."
6600 @ -30C is the 5W oil requirement, 7000 @ -25C is the 10W grade requirement.
The Low Temperature Pumping requirement is 60,000 cP across the board at a different temp for each grade.
The Castrol GTX 5w30 is listed at 40,000 and the 10w30 at 50,000 to indicate that these grades meet the GM 6094M cold flow spec.
Note - Most 5w30 conventionals are around 25,000 @ -35C, Valvo All Climate is 22,000 cP pumping viscosity.
The current SM rated Conoco and Phillips 5w20 and 5w30 synthetic blends have cold crank values of 3,700@-30 and 5,300@-30 respectively. They may be the value leaders in cold flow oils.
