General wet sanding of metal....different uses in that area though.
Don't think that I have ever seen lower than 220 locally.
Is this waterproof stuff the same as the Wet dry that you buy in parts stores?
Aluminum Oxide Cloth Sanding Sheets
The most popular choice for general purpose sanding of metal and wood. All are 9" x 11".
Dry Sheets— 36-60 grits have a strong, stiff backing; 80-500 grits have a flexible backing.
Waterproof Sheets— Unlike dry sheets, these products resist water as well as grease, chemicals, cutting fluids, and other solvents that may be present when sanding, deburring, cleaning, or polishing. Backing is flexible.
Sheets
Pkg. Pkg.
Grit Qty. Per Pkg. Qty. Per Pkg.
Dry Sheets
36 25
4671A23 $37.43
5
4671A79 $10.51
40 25
4671A22 33.61
10
4671A78 14.67
50 25
4671A21 30.98
10
4671A77 13.78
60 25
4671A59 28.81
10
4671A76 12.73
80 25
4671A58 24.48
10
4671A69 10.64
100 50
4671A17 45.12
10
4671A68 10.00
120 50
4671A16 45.39
10
4671A67 10.00
150 50
4671A15 45.39
10
4671A38 10.00
180 50
4671A14 45.39
10
4671A37 10.00
220 50
4671A28 45.39
10
4671A36 10.00
240 50
4671A13 45.39
10
4671A35 10.00
280 50
4671A27 45.39
10
4671A34 10.00
320 50
4671A12 45.39
10
4671A33 10.00
Pkg. Pkg.
Dry Sheets (Cont.)
400 50
4671A11 $45.39
10
4671A32 $10.00
500 50
4671A26 47.90
10
4671A31 10.19
Waterproof Sheets
60 50
8270A58 52.39
10
8270A78 12.53
80 50
8270A57 48.46
10
8270A77 11.76
100 50
8270A56 45.94
10
8270A76 11.25
120 50
8270A55 45.94
10
8270A75 11.25
150 50
8270A54 45.94
10
8270A74 11.25
180 50
8270A53 45.94
10
8270A73 11.25
220 50
8270A31 44.61
10
8270A32 10.99
240 50
8270A52 45.94
10
8270A72 11.25
320 50
