Originally Posted By: onion
Critic- I want to know something. What are your qualifications?
Every time a thread regarding Dexron VI is posted, you're among the first posts, loyally defending Dexron VI. That's all fine and good with me- it seems to be a vast improvement over Dex III. But I have a problem with some of the advice you've given (here and elsewhere- it's often nonsense). A screwed-up filter installation will not cause a 'clunk'. Can't happen. Sure, it can cause other problems... but 'clunk' is not among them. Personally, I blame either an over-active imagination or excessively dirty fluid before the service.
So... under occupation, you've listed "sales". It used to say "student". Perhaps you've finished school and now you sell Dexron VI? What exactly qualifies you to parrot advice all over BITOG when you clearly have no mechanical background?
Onion,
I responded to this thread as I wanted the OP to understand that Dexron-VI is not thinner than Dexron-III. I mentioned the filter and the o-ring as something to check, as it may possibly be the cause, or not. Either way, I wanted him to understand that the fluid type is not the problem and that he should look elsewhere.
As for the advice I give, I always try to research the subject and consult with a variety of sources before I post on here. I always strive to be accurate—please PM me and show me where I have been giving bad advice; I would really like to know and correct any misinformation. For the record, I am not affiliated with any auto manufacturers nor do I sell any automotive parts. As for my qualifications, I do not think I’m any different from many of the other members on this forum. I research the questions that I answer prior to posting, and I try to consult with professionals in the industry (including OEM) to gain different points-of-view. While I may not be a professional mechanic as you are, it does not mean that I am not qualified to give any advice. If that were the case, it would disqualify many individuals on this forum from participating.
