MolaKule
Staff member
Special Relativity
Without having illustrations, this might be more difficult, but here goes.
Reference Frames:
When you pass me going down the highway, my speedometer is showing 70 while yours is showing 75. A person standing by the road is seeing your speed as 75 mph, but your speed relative to mine is 5 mph.
A reference frame is a coordinate system in which experimenters equipped with meter sticks and stopwatches to measure length, time, and velocities.
1. A reference frame extends infinitely in all directions.
2. 2. The experimenters are at rest in the reference frame.
3. The number of experimenters and their equipment are sufficiently accurate to measure positions and velocities.
A reference frame is not the same as “point of view.” All experimenters at rest relative to each other share the same reference frame.
Let’s take another example. A 300 gram ball moving to the right at 2 m/s has an elastic collision with 100 gram ball moving to the left at 4 m/s. What are the direction and speed of each ball after collision (momentum is conserved). The stationary reference S is the frame in which the 300 gram ball is moving, and the reference frame S’ is the reference frame in which the second (100 gram ball) is moving. In the reference frame S’, the balls before collision are moving at 6 m/s and 0 m/s, respectively. After collision, in the reference frame S’, the large ball is moving at 3 m/s to the right and the small one is moving at 9 m/s to the right. In the reference frame S, the large ball is moving to the left at -1 m/s and the smaller ball is moving to the right at 5 m/s.
Time Dilation:
The reason clocks show different elapsed times when moving relative to each other is because of time dilation. Now speed or velocity is = change in distance/change in time, or as we say, v = del x/del t, the ratio of distance traveled to the time interval the test is occurring. Suppose we do a test in which the lamppost on our street is the marker for timing and measuring distance. Your driving by in your car and I’m standing still, and we’re both measuring the velocity of a bicycle. The velocity measured by you and me will be different for the bicycle because your reference frame is different from mine. Your change in distance and my change in distance will be different because we are in two separate reference frames. You will show v’ while mine will show v.
Repeat the measurement with the velocity of light as it travels from the tree to the lamppost. Once again, your change in distance will be x’ while mine will be x. The obvious conclusion is that you will measure v’ for the light and I will measure v, but this conclusion is not correct, because the speed of light u will equal u’, since light travels at speed c = u in ALL reference frames, that is, u’ = u. The only way this can true is that your change in time is NOT the same as my change in time, that is, t does not equal t’. We then have to change our understanding of time. In this case, the speed of light is the same, the measured distance is the same, but the variable that has changed is time. Therefore, in your reference frame, time has shortened. For clocks that travel around the world or at high altitudes, their time has dilated. Your time on the ground has remained constant.
And that’s why when clocks fly, time does not!
Reference Frames:
Time Dilation:
