cleaning stainless bowls
soak some paper towels with CLR or Lime Away and line the bottom of the bowl with the wet towels. Let sit overnight. Scrub and rinse and you're done.
This method requires far less CLR or Lime Away and holds the chemical in contact with the grit.
Originally Posted By: bmwjohn
I have several stainless bowls that I use for dog water, keep them full so if I am gone (or die) dog may be hungry but not thirsty until someone shows up or I get back.
If you die, make sure to put extra food down or the dog will eat you. Seriously.
