Cleaning Funnels
I don’t like to waste brake cleaner if I don’t have to, so unless it’s really dirty, I wipe them out with a semi-clean microfiber shoved through with a screwdriver. I have one that I use exclusively for waste oil that never gets cleaned.
I have got to stop reading post's early in the mornings. I saw the header "cleaning funnels" and the first thing I thought was what the heck is a funnel for cleaning 🤣. I get it now, cleaning a funnel.
C'mon man, we ain't using present participle adjectives. We're talking progressive verb tense.
My brain does struggle with this, too. Do they mean adjective or verb...
  • Like
Reactions: Arc
The older I get the slower I get. Maybe I just more sleep and less forum time.
All kinds of different ways to clean a funnel. The fastest and most convenient way I suppose would be brake cleaner and compressed air.
That's if you have compressed air available and can afford the price of brake cleaner at over $6 a can just for cleaning funnels.
What other ways are there to clean a funnel?
Isopropyl Alcohol
Every funnel gets wiped down with a blue shop towel after use and stored in a plastic bag. (Each funnel has its own bag.) Then they’re stored in a cabinet until needed. When I take one out to use it, it’s still clean.
I also have a dedicated waste fluid funnel that never gets used for new fluids.
Put some gas down the oil funnel into a mower.
If I don't need to put gas in anything then I put a paper towel in a grocery bag and tie a sheep knot in it to keep the dust off it.
It can get rather dusty here.
Quick shot of brake clean, then hand wash with hot water and Dawn dish soap in the laundry sink. Air dry, then they go back in their dedicated bin. I must have 15 funnels in that bin, but I usually only use one of my three or four favourites.
A paper towel is going to leave all kinds of lint fibers behind. How can you stand that?
A residual amount of cellulose fiber is unlikely to be a problem in any equipment I own even if it is left, IMHO.
I doubt that those stray cellulose fibers are significantly different than any stray cellulose fibers that come from the filter element itself or fiber board end caps. Can't see a problem here.
