Clay how to
Corunna, Ontario, Canada
Have heard and read about the clay bars and clay in general, but I have no clue how to clay the paint.
Could someone tell me how it's done, what it does for the paint, and what to do afterward? Do you go on to waxing/polishing or no?
Thanks.
Clay will get contaminants that washing wont, The most popular reason to use it is to get the surface smooth when it gets rough and even after a wash the surface is still rough. This means you have embeded contamination and the only thing that will get it is claying or polishing. Claying is less aggresive so it's more desirable. Only polish if you have to, IE you have swirls or oxidarion and you want them gone. You can also use clay to get stuff like overspray and brake dust and plenty of other things that stick to paint.
Think of paint like a test and clay like an eraser, the only difference is that you need to keep the eraser and test lubricated with a lubricant or the paint will get swirled. But the motion you'd be using is like an eraser, many passes with medium pressure. Use a clay lube until you have used it alot than you can try other stuff like washes. Clay lube offers the most lubricity.
You can wash your car after, but it all depends on what you are doing. If you are going to wax, or not. I only use Zaino anymore so after claying I wipe the surface down with Z6 and then apply Zaino's Z5Pro and Z2pro. If you aren't waxing, it might be possible just to dry it depending on the lube. For more info check out detailersclub.com. Peace
FYI, I tend to clay the lower portion of my car twice a year to remove tar, etc. from the panels. Not as much of an issue on the flat surfaces for some reason. I think It is becasue the car is kept fairly clean and polished. I also now use Duragloss Aquawax as a detail spray after each wash. It keeps the surface very smooth, hard and slick feeling.
1. Wash and dry vehicle.
2. Spray lubricant on a section of the vehicle. Lubricant is usually just some quick detailing spray.
3. Rub clay over surface until it slides smoothly.
4. Wipe off excess lubricant.
5. Repeat on new section.
6. Knead clay bar once you see lots of dirt on it.
7. Once whole vehicle has been clay'd, wax it.
Clay barring can be time consuming on some vehicles, but the results can really be worth it. I clay'd a truck that had gotten a lot of spray paint overspray on it. It looked brand new afterward and the paint was smooth as silk.
thanks for the articles,
I can confirm that clay can haze the clearcoats, did it on my black car and it took a bit of polishing to get it out but at least it was in an inconspicuous area.
The new sonus green clay sounds like it might be worth trying.
I didn't know about the hazing the clearcoat thing... I guess I'll have to be careful, my car is dark red.
I did my car for the first time before the winter set in, and it was a hoot. Used method described above. I got a Meguiar's kit from Advance Auto for < $20.00 which came with a bottle of quick detailer and a bar of clay. I washed the car extra-extra thoroughly before I started, and the clay was still pretty dirty in the end. You can hear tiny, crunchy "pops" every once in a while as you slide the clay over the paint. Thought that was pretty neat! It made the paint REALLY slick considering it hadn't been waxed, though I did use a quick detailer, so that probably acounts for some of it. At any rate, the wax/sealant/whatever I used (Nu Finish) went on a lot easier/more evenly than it usually does afterwards. I suppose only time will tell if it lasts longer when I clay the car first.
The only thing I was kind of surprised at is how much quick detailer spray I had to use - over half a bottle. If I didn't have LOTS of spray on the surface, the clay was hard to drag across, and it felt like you were smearing the clay into the paint. I'm curious to see how plain soap and water will do. Anyway, it's not especially difficult. Have fun!
I'm pretty sure you can mix a capfull of your choice of liquid carwash detergent (non-abrasive) with water in a 12-16oz spray bottle and have a good solution for the detailer spray. All it has to do is reduce the friction.
