Is it the MP series ST filter? (Blue one I think)66 Barracuda. Last oil and filter change (w/ SuperTech) 6/2022. Have driven 1k miles since then. going to change oil but should I change filter? I know 1k miles is minimal but does the 2 years come into play?
Standard ST filterIs it the MP series ST filter? (Blue one I think)
I'd say if you could get an extended mileage type filter then keep it on for 5 years if you'd like. I think the ST to be a decent filter & with just 1k on it I'd see no reason not to run for another year or two. Next go just think about an upgraded filter to run your extended time table.
I believe a standard should be good for 5000 miles. Just did not know if time is an issueStandard ST filter
The only thing that would be of concern to me (although not of much concern) would be the nitrile ADBV getting stiff do to age.Standard ST filter
I was looking through my owners manual and service manual and they both say every other oil change for the filterFresh oil Fresh filter.
Remember the reason the car company is in business is to sell cars.....Thats my opinion... Fresh oil Fresh filter.....I was looking through my owners manual and service manual and they both say every other oil change for the filter
Yes.. What engine is in it ???We need to see a photo of this Cuda.
If you are going through the effort of changing the oil, why skimp on reusing a three dollar filter?66 Barracuda. Last oil and filter change (w/ SuperTech) 6/2022. Have driven 1k miles since then. going to change oil but should I change filter? I know 1k miles is minimal but does the 2 years come into play?
Seems like a no brainer......If you are going through the effort of changing the oil, why skimp on reusing a three dollar filter?
Been proven that oil filters start losing efficiency as they load up. It's a misconception that they "get more efficient" with use. Air filters do, but oil filters don't. The only time oil filters "get more efficient" is basically when they are nearly totally loaded to the point the bypass valve is opening way too much.Theoretically, a partially "loaded up" oil filter (or almost any kind of filter) should work better at filtering than a brand new one would.
