Originally Posted By: CentAmDL650
I have an 01 Chevy 2500HD with 6.0 auto, and the brake booster is hydraulic - part of the same pump that runs the power steering. I don't know, but do the non-HD models have vacuum-boosted brakes?
If I had to guess, I'd go with something in you 4L80E auto transmission, check the AT fluid level, and maybe think about a filter change, fluid change and/or fluid flush.
When you have a wheel sensor problem, usually the noise comes from the ABS module when applying the brakes.
Yes, it runs the power steering pump as well. And it does not have to do with the brakes. It only clacks when accelerating. Ill be interested to find out what it is. If the noise continues It will probably be checked out next week.
