I think if you have a daily driver and run under normal service situations, then changing your fluid within 30,000 miles, the HK DIII/Mercon would be fine. The reason I say this is because of the additive package. If you are pulling loads or running in exteme heat at high speeds, then you are running in severe service conditions, and you may want to change fluid in less than this interval.
Now synthetic fluids have longer lasting (and more expensive) additive packages because they are expected to have > 50,000 mile longevity.
This is one of the reasons why the GM DIII(H) spec is on the scene. They expect these Factory fill fluids to last approx. 100,000 miles in NORMAL service, whatever that is defined to be. These fluids will have to be synthetics or Group II/IV blends.
[ April 28, 2004, 08:00 PM: Message edited by: MolaKule ]
