CI-4 oils?
Bad Axe, MI
I love the stuff! but getting hard to find i have two old Fords that i run it in(also my ATVs) the only place i have it available is TSC and my JD dealer, Anybody know how good the traveler(sp?) or Mystic(sp?) 15w40 CI-4 oils are? anyone know of OR have VOAs or used oil analysis i can look at,i know it'll have a boosted ad pack being CI vs CJ but still dunno how it would stack up.
search gave me nothing really....
Mystic makes good stuff. Traveller is the house brand of TSC. Rural King has a similar product.
You'll be fine using any of them.
Here's a question that's a little off-topic, but if I remove my DPF, is there any need to avoid CI-4 oils in 2007+ diesel trucks?
No
Originally Posted By: BoiseRob
You can still get Delo 400 Multigrade, It's CI-4+.
from where rob? like to stick with local OTC..
We use Service Pro 15w40 that is a CI-4 Plus oil in all our farm equipment. We get great oil analysis back with it. The Auto Value near where we live sells it. I see you're on the east side of MI. Rowley's Wholesale, out of Bay City, is where we get most of what we use. They deliver right to us.
Any Chevron Distributor. We have 3 in town and they all carry it. You have to buy it by the case which is 6 gallons...
I thought EGR was another area that benefits greatly from the CJ4 oils as well as the DPF although I am speaking mainly from experience with the Ford trucks.
Bill
EGR should be handled just fine with CI4+ oils. CJ4 has a bit more soot dispersancy on the average, but CI4+ has better acid neutralization viz. higher TBNs.
Now if you disconnect/block the EGR, one can use numerous excellent CH4 oils, i.e. John Deere +50 0W40, or what I use in my Unimog*...
*designed for European built engines only like MB, MAN etc.
Charlie
Amsoil still has their CI4 oil.
But if you are running ULSD, the new CJ4 oils are supposed to be better.
I know i keep hearing that, BUT i want the higher anti-wear levels and detergents the old CI4 has,i do run LSD(115ppm)(Red) in them.
That's because you da Man
I just want what i want...
plus 50 II cj4 is supposed to now be available, my local deere dealer has alot of the ci-4 plus in stock. it will probably take 6-12 months to fully phase-in the new oil.
the new plus 50 II 0w-40 is supposed to be ci-4 plus
Yea mine said they havent had any CJ-4 in the pipeline yet so i may grab a few more pails of CI to really stock up,was hoping JD would have kep with CI-4 darn it.
the 0w40 is crazy priced, $133 for a 5 gal pail!!!
