Oil guru's...aside from higher zinc and phosphurous additives in CI-4 oils, and maybe better TBN retention...are there anymore benefits to these oils vs CJ-4 oils? Amsoil in particular still recommends CI-4 oils for 1st choice for vehicles in the pre-2007 category without DPF filters. I know that CJ-4 oils have proven to be very worthy as shown in used oil analysis, but if I can benefit for from a CI-4 I might go that route instead. I am starting to look at amsoil's HDD series 3000 5w30 (CI-4) a bit closer now as far as using it, I am gaining more trust in using a 30 wt oil in a diesel engine now after seeing "Dnewton3's" and "arkapig's" results in a duramax engine with a CJ-4 10w30. This amsoil HDD is at the higher end of the 30 wt spectrum at 11.7 cst..and after reading more and more about this oil, it seems pretty robust and shearproof. I emailed amsoil tech service years ago to inquire about this oil, and was told that a conventional 15W40 once heated to about 280 degress is about the same viscosity as a 30wt anyway, and that their HDD oil remains in grade at even hotter temps, and resists breakdown. I guess with this CI-4 oil even if I did encounter "breakdown" I would have the extra antiwear addtives to help out with "boundary lubrication". Chime in all!
