Chopped or feathering type tire wear.
Originally Posted By: Dwight_Frye
I had a 2004 Infiniti G35 Coupe bought new. By about the first 8000 miles the front tires were cupped and making a lot of noise. It turned out that the factory alignment specs were wrong. The dealer pro rated the tires and provided a new set and adjusted the alignment according to the TSB. No problems after that. So, it may be that the factory alignment specs for the Mustang were wrong. I forget whether it was a caster or camber problem with the Infiniti, something to do with supposedly having better handling when set up from the factory that in practice wasn't such a good idea.
I have an Alldata subscription for this car and don't recall seeing any TSB info about tire wear but I will go back and look to make sure.
CapriRacer says he believes the factory spec range for my car is too generous so I'm going to see if I can get anyone to set my alignment to the specs that CapriRacer suggested.
Wayne
