Choosing the Best Oil While Cleaning With Auto-Rx.
Originally Posted By: mikeh1959
is reg motor oil or synth oil a better protection
Syn Oil of course.
Better cold weather starts, better heat resistance, usually better additive package to keep engines clean.
There's no magic oil. In extremes.. synth oils endure or perform better. But going down the road ..not usually. They may last longer in service without issues.
Many synths aren't marketed as extended drain oils and have unremarkable additive packages. Others will be targeted toward extended drains (which may be time weighted instead of mileage weighted) and they tend to have additive levels to meet those goals.
I agree with what you are saying Gary. From a consumer standpoint, how do you know which is designed towards shorter run proficiency vs. extended drain proficiency? All we see is marketing spins on TV. Kind of like the government.
Most of the true extended drain oils promote it. Amsoil is all about it. I wish I could say more, but that's about it. Even the XL line up is beyond what most consumers are going to dare and attempt.
M1 promotes their EP line up. I imagine it's targeted toward those with OEM recommendations that are spec'd with conventional oils. The rest are carrying the spec's of the various vehicles that are recommended with (by our standards) extended drains by their manufacturer (BMWLL/MB229.x/VWwhatever).
Pennzoil doesn't appear to promote extended drains ..and appears to have a whole line of Euro spec oils that are distinctive from their "normal" Platinum line up.
APPLICATION
PENNZOIL PLATINUM ® EUROPEAN FORMULA 5W-40 full synthetic motor oil can be used in both passenger car
and light duty diesel applications. It is recommended for BMW and Porsche vehicles and where Mercedes-Benz
Approval 229.5, VW 502 00, VW 503 01, or VW 505 00, Porsche, BMW LL-01, and Chrysler MS-10725 performance
is required. PENNZOIL PLATINUM ® EUROPEAN FORMULA 5W-40 meets or exceeds the performance
requirements of API SM/CF, and ACEA A3/B3/B4-04. PENNZOIL PLATINUM ® EUROPEAN FORMULA 5W-40
cann be also be used for other vehicles where these performance requirements are recommended.
• Has MB – Approval 229.5
• Has VW 502 00 and VW 505 00 approvals, Meets VW/Audi 503 01
• Approved to BMW LL-01 specification
• Has Chrysler MS-10725 approval
• Has Porsche approval
• Meets or exceeds the requirements of ACEA A3/B3/B4-04
• Meets or exceeds the requirements of API SM/CF
Here's the regular PP
SPECIFICATIONS & APPROVALS
PennzoilÒ PlatinumÔ exceeds:
North American warranty requirements for U.S., European and Japanese cars and light trucks with gasoline and gasoline turbo-charged engines where API SM and earlier API categories are specified (all grades)
North American warranty requirements for U.S., European and Japanese cars and light trucks with diesel engines where API CF oils are specified (10W-30, 5W-50, 15W-50)
ILSAC GF-4Energy Conserving performance standard (0W-20, 5W-20, 5W-30 & 10W‑30)
Meets the most advanced emissions and fuel economy standards in the US gasoline powered engines.
Meets Chrysler MS 6395Q (5W-20, 5W-30, 10W-30)
Meets Ford WSS M2C930-A (5W-20) and WSS-M2C929-A (5W-30)
Meets GM 6094M specification (SAE 5W-20, 5W-30 and SAE 10W-30)
Meets GM 4718M specification for Corvette (5W-30 and 10W-30)
Meets Acura HTO-06 for turbo-charged applications (5W-30)
Meets demanding ACEA requirements
Here's the notation about the different line
PennzoilÒ PlatinumÔ is also available in several European Formula grades suitable for many of the premium and high performance cars from European manufacturer’s. See separate data sheets for each PennzoilÒ PlatinumÔ European Formula product. PennzoilÒ PlatinumÔ European Formula SAE 5W-40, PennzoilÒ PlatinumÔ European Formula SAE 0W-30, PennzoilÒ PlatinumÔ European Formula Ultra SAE 5W-30, and PennzoilÒ PlatinumÔ European Ultra Diesel SAE 5W-30.
In short (never with me), if you look at what the oil is spec'd for, you can get an idea of its endurance. Most of our popular (read cheaper) synths that aren't HDEOs, aren't designed for much beyond the OEM spec's for your average North American passenger car.
