I read this post on another forum and thought it was good post for the type oil to use with ARX.
I think that PP (and other synthetics) has gotten a lot of press on message boards inadvertently. There are a lot of folks that will not run dino oil in their motors. This may due to it being a sludge proned design. Or it may be a turbo or may be in real frigid climate. PP or any Group III has bridged a gap with these customers. Still basically a dino, but better refined. But to think PP or any group III is going to do any real cleaning of a dirty motor is false. I am still a Pennsoil Yellow bottle fan, personally. But that is mostly due to convenience.
To answer the original question, I would also recommend running a mineral oil in the proper weight and viscosity designed for your motor.
This would be for both phases, cleaning and rinse. There is likely many brands to choose from. Think cheap, think conventional oil. First of all the cleaning phase is for only 2500 miles. Why spend any more money than you have to on a 2500 mile oil change interval. When it comes to the rinse phase, another 3000 mile short OCI, I recommend the same.
It is particularly important to run a conventional oil during this 3000 mile rinse. Reason being is that for contaminants to rinse off metal surfaces a simple mineral oil with no polar properties works best. Most full synthetics and semi-synthetics contain polar ingredients. By polar meaning having an attraction to ferrous metals in particular. This does not bode as well for rinsing.
When you come right down to it, it is more important to run conventional or a group III, if you must, during the rinse, as opposed to the cleaning phase.
