Chirping noise from Ford 3.0 Vulcan engine
Michigan
If you hear a strange chirping noise coming from your Ford Taurus or other Ford vehicle that has a 3.0 V-6 engine it is probably the Cam Synchronizer bearing going bad. This looks like a small distributor when pulled out and it sits under the air intake area. It can be replaced for under $ 75.00 by someone with decent do it yourself skills. If Ford does it it can be expensive.
A reasonable person could do it in a hour or so.
Dealer part alone is over $ 200.00 then the hour or so labor so over $300.00.
The 1996-2003 Ford Windstar 3.8L had the same cam sync sensor, that occasionally has the same issue. Kind of rare, but it did happen. Chirp-chirp-chirp.......
Joel
People at Taurus car club are saying the Dorman replacement is not the way to go. Seems the OE Ford part or some other reputable company is the way to go.
I bought a Dorman coolant bottle from Dorman "Taurus" and it leaked at the welded seam. I bought a new bottle from Ford.
I got a Dorman part and my brother in law replaced it. My daughter said it is still making noise on and off. Not sure if the Dorman part was bad or it was not lubed well before install.
But I would probably not go with the Chinese made Dorman part again.
The Ford 3.9 and 4.2 V6 can have the same problem. When the sensor does that, it can cause the engine to stall, because the engine computer cannot time the spark.
Anyway, many cars go for 10 years and 200,000 miles without a single sensor dying, so I wouldn't call the Motorcraft part an A+ quality part. That in mind, many cheap replacement sensors are terrible.
