53' Stude
Thread starter
This shows all of us how very labor intensive steam locomotives were/are
https://youtu.be/foneS2GhpUg
JHZR2 said:I was kind of surprise they were still mostly coal fired. Most steam engines in the US were using fuel oil because it's more fuel dense and considerably easier to manage. Having to refuel coal and stoking it is highly inefficient, but manual labor is still cheap there.
Fuel oil was primarily a western thing, where coal was less available. Also, before the widespread use of plastics, bunker C, which is what almost all oil-fired steam burns, use to be almost free garbage from the oil companies. It's now valuable both as an industrial feedstock and for "cracking" into lighter fuel. In any case, I'd venture to guess that it takes longer to pump a tender full of viscous fuel oil than it does to drop a few tons of coal into the hopper. Here east of the Mississippi, coal is plentiful and few if any steam locomotives ran oil.
Folks I know who have hands-on experience with both say that it's all in what you know. Oil is somewhat easier to fire in the sense that you can increase/decrease the fire size with a lever(you can dump a coal fire quickly, but building one up takes a few minutes warning) although oil comes with its own issues. If you get too much draft through a coal fire, you MIGHT start pulling it off the grate, but you'll probably notice it before anything bad happens and can close the dampers or do whatever you need to drop it. On the other hand, with oil in the same situation it's possible to kill the fire completely and you don't want to have to try and re-light it when you're climbing a grade and need steam NOW.
Modern/larger steam locos(including the QJ class) have stokers, which are basically just an auger that runs in a trough from the coal bunker in the tender to the firebox. A single fireman manually shoveling couldn't keep up with even a QJ, which is actually a bit small by American standards. Although the fireman DOES generally have to manually shovel some coal, it's usually just to control specific areas of the fire. The stoker dumps most of the coal needed-the fireman just needs to know when and how quickly to add it-although of course there's a LOT of skill involved in knowing that in the first place(and also watch/adjust the water level, which is perhaps an even more important job and is the same on oil and coal both).
It's worth mentioning that although the Union Pacific was/is the last railroad to OPERATE steam(since in 2019 they have a fleet of three locomotives in revenue service, two of which were never removed) and primarily use oil on their late stuff, the Norfolk and Western was the last railroad to actively develop steam and the last to phase it out on a large scale. The N&W was primarily a coal road, and even their A, J and Y class locos built in the 1950s were coal fired.
I heard in California any steam locomotive needs to be certified every 10 years. The California State Railroad Museum was running a steam locomotive for a 3 mile out and back excursion trip using the Granite Rock #10. But I remember they started running a diesel. I was asking volunteers at the museum what the deal was, and apparently the boiler needed to be rebuilt. They also had a couple of donated steam locomotives that weren't in running shape and were left on a siding where they were collecting graffiti. They finally rebuilt the boiler a few years back and are running steam again. I was always impressive when they did a blow off before reversing.
I live fairly closed to a miniature steam train setup. They run it on #2 fuel oil, which their volunteers (and maybe one paid employee) say is because they don't have to pay road taxes. I've heard that the Disneyland Railroad runs a B98 biodiesel using every bit of waste oil generated by their restaurants and then some. Apparently the petroleum diesel they use is regular diesel #2. Probably not a big expense in fuel taxes anyways.
I haven't seen a coal fired steam locomotive in person. I thought maybe they had one at the California Pacific Railroad (aka the Skunk Train) up in Mendocino County.
We've got a bunch of mini steam powered railroads around here. There's the Redwood Valley Railroad near Berkeley, the 22 inch Little Puffer at the San Francisco Zoo, the Billy Jones Wildcat Railroad in Silicon Valley, and Sonoma Train Town in the city of Sonoma. The last one they operate a diesel hydraulic locomotive in the off season.
I mentioned the California State Railroad Museum, where they've got a bunch of non operating steam locomotives. I suppose the most unique is the last remaining cab forward steam locomotive in existence - the Southern Pacific 4294. Something about putting the cab at the front to avoid all the smoke when going through several tunnels through the Sierra Nevada. There was talk about restoring it to operating conditions, but the cost is too prohibitive.
