ChevronTexaco Havoline 10W30 VOA
Spring TX
Oil type: ChevronTexaco Havoline 10W30 SL Dino
Oil interval: 0 miles (virgin sample)
Data from bottle: ATL 15:19 07-30-03 / BN824367T 08/02/03
Lab used: Blackstone
Sample date: 01/04/04
Report date: 01/12/04
code:
Aluminum 0
Chromium 0
Iron 1
Copper 0
Lead 0
Tin 0
Molybdenum 43
Nickel 0
Manganese 0
Silver 0
Titanium 0
Potassium 0
Boron 117
Silicon 2
Sodium 0
Calcium 1658
Magnesium 24
Phosphorus 654
Zinc 822
Barium 0
SUS VIS@210F 63.6
Flashpoint 435
Fuel% 0
Antifreeze 0
Water 0.0
Insolubles Trace
TBN 8.1
Blackstone comments: No problems showed up in this sample of Virgin Havoline 10W30 engine oil. This is a common additive package and should do well in about any type of engine. The TBN read at 8.1. We don't consider the TBN to be a problem until it starts to read at 1.0 or lower. The trace of insolubles and 1 ppm iron are nothing to worry about. These are both common finds in virgin oils.
My comments: Light amber color, no solids visible when holding sample bottle up to the light. Data on bottom of bottle shows that it was probably bottled around late July, early August of 2003. This should provide a good comparison to the Chevron VOA we have on file for about that same time period
This is pretty identical with the Chevron Supreme 10W30 VOA.
Let's compare this to the Super Tech 5W30 VOA
Copper 0
iron 0
Chrome 0
Sodium 0
Boron 0
Alum 1
Moly 55
Phos 1122
Zinc 1090
Mag 4
Calcium 1934
Viscosity cst 10.50
SAE/30W
It has been said that this oil has a weak additive package.It looks pretty comparible and better in some cases opposed to Chevron/Havoline.
What say you?
I say ChevronTexaco is geared up and just about good for the go for API Catergory SM
I like the boron too Patman
A big chunk there for a low cost oil .
We need to see the new Chevron Blend now the curiosity in me say's
After looking at some of the used oil analysis of the cheap Supertech oil, it's my opinion that though there may be minuscule differences in viscosities and additive packages, SL rated conventional oil is SL rated conventional oil. It is very unlikely that anyone would get longer engine life by switching from Supertech to Havoline or Mobil to Chevron. I really don't think your engine gives a hoot as long as it is on a reasonable OCI.
http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;f=3;t=000823#000000
http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;f=3;t=001172
Gary, I think if you take those two oils and run them in a moderately driven car in a mild climate, you'd see similar results, but where I think the difference lies is in more extreme conditions.
Having the better additive package could mean that those who drive harder or live in slightly less perfect climates, will have that little bit extra protection.
