2005 Toyota Matrix
1ZZ-FE Engine
4,939 total miles
2,366 lube miles
Chevron Supreme 5W30
Toyota OEM Oil Filter
The first column was the factory fill. Oil currently in the crankcase is Mobil 1 10W30.
Miles 2573 2366
Fe 19 7
Cr 0 0
Ni 0 0
Al 8 3
Cu 87 13
Pb 3 3
Sn 3 0
Si 227 44
Na 18 3
K 24 2
Mo 96 72
Sb 0 1
Mn 6 1
B 4 99
Mg 19 8
Ca 1759 1920
P 769 809
Zn 924 969
Fuel % vol. 4.5 .5
Soot % vol. H2O Viscosity 100 C Cs. 8.4 8.6
TBN 2.50 3.23
Polaris flagged the viscosity as "slightly low" and the silicon as being at a "moderate" level. I was happy to see that the fuel dilution is now normal. The car was driven a lot harder on this OCI, but wear metals continue to trend downward as the engine loosens up. The car has noticeably more pep down low according to my seat of the pants dyno.
Comments always welcome of course!
1ZZ-FE Engine
4,939 total miles
2,366 lube miles
Miles 2573 2366
Fe 19 7
Cr 0 0
Ni 0 0
Al 8 3
Cu 87 13
Pb 3 3
Sn 3 0
Si 227 44
Na 18 3
K 24 2
Mo 96 72
Sb 0 1
Mn 6 1
B 4 99
Mg 19 8
Ca 1759 1920
P 769 809
Zn 924 969
Fuel % vol. 4.5 .5
TBN 2.50 3.23
