Chevron DM or Castrol Multi
WA
I have a 05 Sentra. I used Nissan's Matic D @ 15K and 30K. I plan on doing OCI's every 10K now. It's hard to find Matic D under $6.00 now. So I will probably switch over to one of the two mentioned above.
I can find the Chevron stuff for $1.79 a quart. The Castrol Multi-Import runs about two dollars more. Do you think the new Castrol Import is worth the two dollar more a quart over the Chevron ATF?
I have Castrol MV Import ATF on my Maxima, I must say it is definetly a better brew than the Dexron/Mercon stuff (I am a Chevron geek, but then I decided to try Castrol for a change and I am quite happy).
MV ATFs are a better brew that the regular Dexron/Mercon stuff in my opinion.
Definitely upgrade when possible. Castrol Import multivehicle ATF is a great choice, as is Pennzoils.
Another option is to skip over the Dexron/Mercon and use any Mercon-V.
