Chevron ATF MD-3 in 98 toyota corolla?
USA, CA, OC
Hi guys & gals. I took my Toyota 98 corolla into a shop for a atf flush and the mechanic added chevron atf md-3 to it which I though was only for fords/gm vehicles. Is it ok for my 98 Toyota corolla ? Thank you.
MD-3 is Mercon-Dexron III so you should be fine. Alot of older Toyota AT's take Dexron III.
Thanks, got worried for a second at the shop. Also my car says it takes DEX III but what is DEX III H?
I am not sure. Here is the link to the stuff. HERE
Originally Posted By: Bgallagher
Is that the iso-syn? If that is the case it is a highly refined fluid and is more than good for a corolla.
Chevron stopped marketing Iso-Syn on their "consumer" products a while ago - but I'd still use it with no worries here.
Dexron III(H) was the previous upgrade to Dexron VI.
https://bobistheoilguy.com/forums/ubbthreads.php/topics/729051/Brief_History_of_ATFs#Post729051
Thanks for the link. Great stuff.
Thank you
As long as the manual calls for Dexron III, you can use it. Many Toyota and Nissan transmissions called for Dexron III before the year 2000.
thank you
