Hi guys & gals. I took my Toyota 98 corolla into a shop for a atf flush and the mechanic added chevron atf md-3 to it which I though was only for fords/gm vehicles. Is it ok for my 98 Toyota corolla ? Thank you.
Originally Posted By: fujirio
Originally Posted By: Kibitoshin
MD-3 is Mercon-Dexron III so you should be fine. Alot of older Toyota AT's take Dexron III.
Thanks, got worried for a second at the shop. Also my car says it takes DEX III but what is DEX III H?
Dexron III(H) was the previous upgrade to Dexron VI.
Originally Posted By: nthach
Originally Posted By: Bgallagher
Is that the iso-syn? If that is the case it is a highly refined fluid and is more than good for a corolla.
Chevron stopped marketing Iso-Syn on their "consumer" products a while ago - but I'd still use it with no worries here.
Originally Posted By: artificialist
As long as the manual calls for Dexron III, you can use it. Many Toyota and Nissan transmissions called for Dexron III before the year 2000.
