I just got the results back from my second UOA from Blackstone Labs. This is for my 2005 Honda Pilot (3.5L V6). The oil was from the 37,500 mi maintenance that I did. I used Chevron 5W30 conventional oil (leftover from my previous car). This was the second consecutive oil change while following what Honda recommends for "normal" conditions (7500 mi OCIs).
The results were even better than the previous one which had bulk oil from the dealer. Here's a link to that UOA:
https://bobistheoilguy.com/forums/threads/super-pro-plus-5w20-7295-mi-2005-honda-pilot.87752/
My whole point in doing these used oil analysis was to see if following the "normal" maintenance schedule would be fine. It appears that this is the case. I might do one additional UOA on the Shell 5W20 conventional that I just put in, but I doubt if there'll be much difference (if any).
Comments:
You extended your oil use to 7,670 miles and engine wear stayed basically the same as your first sample. That is a good indication that all parts are wearing normally. This oil uses a different additive package than the previous one and it worked just as well as that one. The oil's viscosity was a little low for a 5w30, measuring in the 5w20 grade range. No gasoline was found to cause it but the lower viscosity was still okay for this V-6. The TBN was 1.2, this time, showing a little active additive left. The air and oil filters were working well. Try 8,200 miles.
MI on oil: 7670
MI on unit: 45,150
Sample Date: 3/10/09
Make up oil added: 0
Aluminum: 6
Chromium: 2
Iron: 25
Copper: 3
Lead: 0
Tin: 2
Molybdenum: 333
Nickel: 1
Manganese: 12
Silver 0
Titanium: 0
Potassium: 1
Boron: 14
Silicon: 10
Sodium: 7
Calcium: 1558
Magnesium: 6
Phosphorus: 587
Zinc: 840
Barium: 0
*Numbers in parenthesis are recommended values
SUS Viscosity @ 210F: 53.8 (56-63)
cST Viscosity @ 100C: 8.41 (9.1-11.3)
Flashpoint in F: 370(>365)
Fuel %: Antifreeze %: 0.0 (0.0)
Water %: 0.0 ( Insolubles %: 0.2 ( TBN: 1.2
Comments:
MI on oil: 7670
MI on unit: 45,150
Aluminum: 6
Chromium: 2
Iron: 25
Copper: 3
Lead: 0
Tin: 2
Molybdenum: 333
Nickel: 1
Manganese: 12
Silver 0
Titanium: 0
Potassium: 1
Boron: 14
Silicon: 10
Sodium: 7
Calcium: 1558
Magnesium: 6
Phosphorus: 587
Zinc: 840
Barium: 0
