+1 on the strainers to catch hair.
I occasionally use lye salt (NaOH) in the kitchen drain to remove grease and organic build up. The drain pipes are ABS so it's not harmful. I use a small amount monthly as preventative maintenance. One $5 bottle has lasted me 2 yrs and it's barely 1/3 used. After you're done, it would be environmentally responsible to run the tap then pure a small amount of an acid such as vinegar or muriatic (HCl) to neutralize the NaOH.
