MolaKule
Staff member
In a New Oils Analysis, which we call a VOA, we typically see small amounts of the elements of Iron, Aluminum, and even Tin at times anywhere from 1 to 3ppm.
In the past, uniformed people, even those in Oil Analysis companies, have claimed that these elements are from Rusty steel containers or other bogus sources.
Contained within BITOG (you have to do your own searching) is the answer.
Additives perform a wide variety of functions within engine lubricants. This includes:
• Protection of engine surfaces. Many additives have anti-wear, anti-rust or anti-corrosive properties, which in combination prevent damage to coatings and surfaces within the engine.
• Modifying the physical properties of the lubricant. Viscosity modifiers and pour point depressants are used to maintain the desired physical properties (most importantly viscosity) at all temperatures and running conditions. This ensures adequate flow and viscosity of engine oil in all circumstances.
• Prevent and control the effects of engine deposits. Additives with antioxidant properties help slow the oxidation process the build-up of undesired engine contaminants and oil thickening. Dispersants and detergents aid in keeping engine surfaces and parts clean alongside controlling deposit mediated engine oil thickening
. • Increased fuel economy. Additives with friction or viscosity modifying properties can also aid fuel economy. This is via the reduction of friction between moving surfaces or providing favourable viscosity profiles that can lead to improved efficiency.
QUESTION: What is the name or designation of this additive agent that contributes to these low ppm levels?
See also:
https://www.atc-europe.org/public/Document 118 - Lubricant Additives Use and Benefits.pdf
https://bobistheoilguy.com/forums/threads/additives-xii-multifunctional-additives.41173/
See also:
