check pump solenoid
indiana
hello all,
i recently got a diesel bosch ve fuel pumped re sealed and i noticed it is not sucking up the fuel. so i bypassed the fuel tank and ran the in fuel line from the pump to a cup filled with diesel. and turned the engine over but the pump did not suck up any fuel. I then checked the shutoff solenoid and it did light up with a circuit tester but that really does not mean the solenoid is working. any suggestions in how to check it? should i remove the solenoid and then see if the pump will at least then suck up the fuel?
well when i checked it with a light circuit tester it lit up when the key was turn over so i know power is getting to it but not entirely sure if its opening when power gets to it. I know if the pump is not sucking up fuel it may be due to solenoid either bad or the fuse blown
Are you air locked? Can you crack a line to an injector to lessen the pressure on the output side?
eljefino "Are you air locked? Can you crack a line to an injector to lessen the pressure on the output side?"
interesting tell me if i understand you right. So their is a possibilty that the fuel lines coming from the back of the pump to the injectors to the engine that their is a block of air disrupting the system. And i should try to lossen the fuel lines near the injectors to allow air to be pushed out?
okay i just tested the solenoid by taking a wire off from the battery to the solenoid and it does click so that is fine.
