A few days ago I posted about an odd experience where a warning light (shaped like a gas pump with "rain drop" looking doodads above it) went off in my '98 Ranger. After doing some searching online, I found that it is a warning light for contaminated diesel fuel. That's all fine and good, since I don't have a diesel and it quickly went away on it's own.
However, yesterday my "Check Engine" light went off for the first time (truck has ~84k miles). Getting a little paranoid, I started through the basics (ie, cheapest fix): Drove all the old gas out (it was from a gas station, WaWa, that I rarely use), replaced the gas cap, poured in a 20oz bottle of Techron, filled it up with a tank of Chevron Supreme, and manually reset the warning light.
If this doesn't fix the problem, where/what should I look at next? Oxygen sensor? EGR valve? Cat?
BTW: I'm doing my darndest to avoid taking it to Ford, so any opinions/advice would be greatly appreciated.
M_C
M_C
