Charging Battery - -Amps?
Check the voltage at the alternator , then at the battery WITH THE CAR RUNNING . tHEN NOT RUNNING .
iS THE BELT SLIPPING ? Check all the cables and connections to be sure they are tight and corrosion free .
Bingo !
Lots of cleaning needed , maybe a new clamp / and / or cable .
Clean the battery post and shine it up . then grease / petroleum jelly on the post & clamp .
Charge the battery well & check / replenish the battery water , if it is servicable .
Check the grounds while you are at it .
Best of luck to you , :-)
