This video shows a completely off grid system that is absolutely capable of charging an EV at fairly high rates. He uses inexpensive used solar panels, imported LiFePO4 batteries, assembled into battery packs and a pair of inverters. A system like this can easily power the daily needs of average drivers. The interesting part is that the battery is large enough to charge the car overnight. Of course, it's a bit more efficient when charging the car during sun shine. However, the LiFePO4 batteries he uses are capable of 2000+ cycles or about 500,000 miles, and the claim is that "IF" properly managed, those batteries could last a lifetime. Also of note, the proper temperature for the batteries is about or around 90 deg F.
I'd very much like to build a system like this. What's interesting is that while there are a stack of losses and necessary compromises, such inefficiencies are easily overcome by, for example, adding one extra solar panel or battery.
