Wanted to ask the question. I'm replacing the valve cover gasket on my 01' Ranger which has about 185k miles on it. Just doing maintance and other things so figured why I am doing injectors/plugs...etc. Might as well change the gasket since everything is apart. Plus gives me the chance to paint the valve cover.
Anyways, this is what the inside looks like. I can get a better picture. Seems to be coated in varnish. NOTE that there is ZERO sludge... anywhere. Just coated. Should I try a different oil or clean it with other products running through the system? I've heard people say seafoam it but honestly I think that stuff is a probably snake oil.
I have been using Valvoline high mileage 5e30 for probably 5+ years and changed it every 5k miles along with motor-craft filter.
Just wanted some thoughts. If all appears normal and this isn't a problem then I will button it up once I am done with everything and continue to do what I've been doing...etc.
Thanks,
-Nigel
Thanks,
-Nigel
