For a 2011 BMW X3 xdrive28i, the standard tire size is 245/55/R17. To replace the tires, low cost options are rather limited, only about 3 that are $250 or less each. (For all-season, only 1 Bridgestone and 1 Pirelli.... and neither seem to be rated well.)
With a slight tire size change to 235/60/R17, there seems to be a lot larger selection available, and the cost for "better-rated" tires can drop may $70-$100 per tire. Or, even the size is changed to 255/50/R17, there are a few other options that are cheaper than the original size, and look better for all-season use.
I know BMW tends to be extremely sensitive on replacement parts for anything, whereas a change like this would be very easy for most other vehicles.
So... Does anyone know how sensitive a BMW like this might be to switching the tire size??? If there is an issue, is there a way to work around it?
